Proble with radio/CD6/Nav works for a few minutes
My 2005 Dodge Durango radio/CD6/Nav has a problem. When it is first turned-on and cold it works for about 1 minute. You can change to Sirrus, FM or AM and the front display is visible. After a minute or so the front display goes black and then only the radio presets work and nothing else until it is a new cold day.
My wife's 2005 Durango started doing the exact same thing and now it doesn't come on at all. You can however adjust the volume and use the radio presets but hat is it. Even on the steering wheel you an only adjust the volume and not the tuner.
Anyone have any thoughts? Fuses on the Durango look good. Are there any fuses hidden for the sound system?
My 05 Durango does it too, I've replaced all fuses just cuz and checked all the wiring and found no issues, I'm almost starting to think that the unit is under powered with the battery not putting out as much juice as it used to, I'm gonna replace the battery and install the auxiliary battery and see what happens
