2nd Gen Durango 2004 - 2009
2007 Durango Steering Column...
Old Dec 26, 2011 | 07:22 PM
omali's Avatar
omali
Default 2007 Durango Steering Column...
I've got a 2007 Durango that was broken into. There was enough damage done that I've got to get the steering column replaced. I've found a replacement but I've got a question before I install - Would I have to reprogram the receiver for the key for the new column or can I leave it as is?
Happy holidays
Old Dec 26, 2011 | 08:32 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
I had problems with my ignition cylinder in that the key would not turn in the ignition if the wheel was turned slightly to either side. I had a locksmith rebuild the ignition and retain my original keys. You may need to swap your ignition cylinder out into the new column,
FF
