2nd Gen Durango 2004 - 2009
Need help with headlight change
Old Jan 2, 2012 | 02:54 PM
Rfdfire592's Avatar
Rfdfire592
Default Need help with headlight change
I just got new sylvania h13 bulbs for my 2006 durango. I got the bulb out from the access panel. But I cant get the bulb off from the wiring harness. I pushed the red button but it didn't move. Any suggestions?
Old Jan 5, 2012 | 02:39 PM
FlyingScot's Avatar
FlyingScot
The red button is actually a "clip". Use your thumbnail and pull it out, not push in.. Hope this helps..
Old Jan 6, 2012 | 01:02 AM
jasonw's Avatar
jasonw
Site Moderator
You may need to take a needle nose or flat-blade screwdriver to pry up the clip. Be gentle with it, pry on the clip and pull on the base of the bulb at the same time. Its a bit hard, but it eventually does come out. Don't "go to town" on the clip to much, I've had those plastic buggers break before on my Ram.
Old Jan 6, 2012 | 08:00 AM
Foskey's Avatar
Foskey
It was a pain when I put in the silverstar ultra's I had little room to work where the Durango was parked. I just ended up pulling the headlight itself and putting them in.
Old May 30, 2012 | 12:04 PM
rdtish's Avatar
rdtish
Default Removing housing
I have removed the access panel on 2005 Durango an turned wheel both ways. But I do not see the nut referred to in manual. Front 2 bolts are no problem. What am I looking for, type of nut? Is it high or low, nearer fender or grille, etc. appreciate any help.
Old May 30, 2012 | 05:58 PM
red hemi durango's Avatar
red hemi durango
its a 10 mm nut high on fender side
