2nd Gen Durango 2004 - 2009
Overhead comp Thermometer stuck
Old Jan 18, 2012 | 11:24 AM
NimrodJess's Avatar
NimrodJess
Default Overhead comp Thermometer stuck
Hello all!
I drive a 2006 Durango SLT and noticed today that the thermometer is stuck at 16* C. Granted, it was that cold a few days ago, but it is warmer now and still hasn't changed, nor does it change inside the heated garage.
I've read that you must drive several consistent miles for it to change, and that has happened more than once in the last 48 hours with no change to the temperature indicated.
Is it as easy as holding the "reset" button like it is with all the other functions of the overhead? Or will that mess with the direction indication as well?
Thanks in advance!
Old Jan 18, 2012 | 08:45 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Mine does this periodically and I just hold the reset button in. It should clear once you pull the keys out,
FF
Old Jan 19, 2012 | 12:07 AM
NimrodJess's Avatar
NimrodJess
Somehow, without poking or prodding, it has worked itself out. It's fine now. XD Silly quirky SUV.
