2nd Gen Durango 2004 - 2009
'05 Durango - drivers door/window switch module
Old Feb 6, 2012 | 11:50 PM
racoon's Avatar
racoon
Default '05 Durango - drivers door/window switch module
My driver's side window and door lock switch module has stopped working for the rear window control switches and partially for the front passenger. The module pops out of the door panel but I don't see a way to open it to clean the inside. Door lock switch is fine and the driver's window switch is fine. Any advise? I can pick up a used module at a wreaking yard, but in time the same issue might be likely. Thanks.
