Advise: Shocks/Struts replacement
Hi all
I am planning to change the Shocks in my 08 Durango, its Hemi 4X4. I need your expert advises for best shocks. My magor drive is on road with all 7 passengers seated & luggage.once in a month offroading in desert. Th OEM shocks went for 35000 Miles max. SO I need smooth ride for long run in heavy weights or no wights. hope this clarifies
Thanks
Thanks
Shahz:
I recommend the Bilstein shocks. If you search the Inet for advice, you should find a lot of positive comments for them.
They carry a lifetime warranty, and a set of 4 should run you around $260-$270 buck shipped to your door.
Check out shox.com.
I got mine from Summit Racing in Akron, Ohio since most places were out of them at the time. Summit was very good about matching the shox.com price as well.
Check out shox.com.
My wife does 99% on road driving, so I put in Monroe Reflex shocks. Not as good (but about $100 cheaper) than the Bilsteins, but they also carry a lifetime warranty. No complaints about them at all.
