2nd Gen Durango 2004 - 2009
04 Durango Limited DVD player installation?
Old May 5, 2012 | 07:57 PM
JHawkk's Avatar
JHawkk
Default 04 Durango Limited DVD player installation?
I recently purchased an 04 Durango. It came with a DVD player but unmounted. All I have is the DVD player, no mount brackets or screws. So I am wondering what I need and how to install the DVD player. Not liking the hole in my roof. If I cant get the dvd player to play I at least want to mount it so it will cover the hole.
Old May 31, 2012 | 09:24 PM
heemi's Avatar
heemi
if its a factory ves system then instal is not that bad. ive done 2 one in an 04 and then an 05. you need a roof mount bracket. you can get at dealer or maybe ebay. and yes this does req. you to cut the roof . but if you can find they have a pre made template witch makes it easier. there are two diff. brackets one for sunroof and one with out. it does make a diff. i may have the template and maybe install instructions. i will have to check. no promises. you will also need two screws to secure it . and the wire harness to run to the radio. sounds bad but if you r handy its really not that bad. just dont mess up the cut in roof. lol. but you will save $$ from dealer. hope this helps..sorry just relised you all ready have to hole. ok then you need bracket ,screws , and the metal clip taht snaps up into the bracket.
Old Jul 16, 2012 | 11:48 PM
Thade's Avatar
Thade
Default 04 Durango Limited DVD Player Installation
I was thinking of putting a factory dvd player in my 04 Durango.It doesnt have a DVD player or sunroof now. I guess from heemi's comments I wont find a wiring harness under the roof liner and I am going to have to get the wiring harness to do the install? comments?
Old Jul 19, 2012 | 07:09 AM
NoFearEyes's Avatar
NoFearEyes
Link for VES manuals --
http://www.imarksweb.net/book/dodge+...system+manual/
Old Jul 20, 2012 | 11:11 AM
Thade's Avatar
Thade
Thanks
NoFearEyes
Was wondering about the technical routing of the wiring systems from the factory. some harnesses are universal to all the vehicles and some are install on order.
Thade
