2nd Gen Durango 2004 - 2009
P0700 and P0750 on '06 4.7L with 545RFE
Old May 9, 2016 | 08:22 AM
Dodgerookie4's Avatar
Dodgerookie4
Originally Posted by Matthew Guilbault
I'm having the same issue and just ordered input and output speed sensors and a governor pressure sensor. I'm reading about solenoid pack replacements and accumulator problems necessitating the installation of a shift pack with a thicker accumulator plate. Haven't dropped the throttle body yet, but I'm hoping to work my way through this with the P0700 codes for improper third and fourth gears. Seems like a lot of people have had and fixed this issue and it's been one of the above? Any thoughts?
After spending a small fortune and replacing every sensor and up to and including two transmissions, I finally ordered a new computer and it fixed it. I ordered from auto computer exchange and they took care of it. The tcm was my problem but the ecm is all one computer on mine so I had to replace the main. Good luck
Old May 10, 2016 | 04:27 PM
Matthew Guilbault's Avatar
Matthew Guilbault
Thank you! I was afraid you'd say that. I suspect the computer is almost the cost of what the truck is currently worth?!
The site you gave me lists a separate TCM from the ECM for a 2003 Durango...
2003 Dodge Durango
4.7L V8 Gas
TCM - Transmission Control Module
$159.00
https://www.autocomputerexchange.com...Bto%5D=&search=
