2nd Gen Durango 2004 - 2009
front right tire locks up... need advice
Old Jul 20, 2012 | 04:19 AM
dcfox43's Avatar
dcfox43
Default front right tire locks up... need advice
Hey so this problem has been with me for many years, what happens is no matter what speed you go from 5 mph to whatever if you have to slam on the brakes or press hard for emergency reason the front right side will lock up and will pull the truck a little to that direction, so many times and recent I bought brakes, rigors, drums pads bleed out the brakes, alignment. I need to know how to fix the problem I'm used to driving it there is times where it looks on me.
Old Jul 30, 2012 | 06:24 PM
n8ech's Avatar
n8ech
DC:
Is sounds like your ABS system is not working correctly if at all.
We need more information though such as year, model, engine, mileage, etc to help you.
Could be lots of things going on here to include a collapsed hose on the left side making the right side do all of the work.
If you have not already, I would plan to flush/replace the oem brake fluid as a preventative measure.
Don
Old Jul 31, 2012 | 12:02 PM
dcfox43's Avatar
dcfox43
I have a 2000, 2wd, 5.2l v8 magnum engine with 192,xxx miles. yeah all the mechanics they say the abs light doesn't show up so its okay, but i disagree i will do the fluid change should i also replace the proportional valve to see if that does anything, ask me anything and i will answer with what i can and i appreciate for helping me and i have realize that i posted in the wrong generation by accident
Old Jul 31, 2012 | 12:22 PM
gertie240's Avatar
gertie240
you didnt mention the caliper. was it changed also?
Old Aug 1, 2012 | 10:08 AM
dcfox43's Avatar
dcfox43
No i haven't change that yet
