engine ground
where is the wire to ground the engine on a 04 durango with a 5.7 hemi? i need to upgrade this wire since i'm getting dimming. I have 4 10'' re audio pro subs with 2 1200sax sundown amps total 2400 rms have an upgraded 320 alternator but i need this thicker wire. please help thanks in advance.
i think this way MIGHT find a loose conection, it was a million years in the army where i leaned this, iam not real sure this will work, but i think it will. get an analog VOM, set it on the lowest DC volt. fire up the electric connection in Q. put each lead on each side of the bolt, ect. if there is a bad conection it will show a small voltage.
LOL I dont know if this is any better than the others but isnt it grounded to the passenger side of the engine compartment (near) left of the battery on a 1/2 inch bolt ????
I might be wrong and if I am I am sorry but its a possible option
Your right it is a ground but its a ground for the battery. I need the actual one for the engine. i'm wondering if they grounded the engine to the battery and then to the ground you were referring to because no one can find it or its hidden lol. Your on the right track though lol.
