2nd Gen Durango 2004 - 2009
need help with some codes on 2007 durango
Old Aug 13, 2012 | 08:34 PM
badone45's Avatar
badone45
Default need help with some codes on 2007 durango
Hi there just looking for some help on some codes for my 2007 durango. Just bought it 2 months ago and i have P0456 and a P0084. Just need help on how these can b fixed? The shop told me the po456 was just evap leak and cus i wasnt turning my gas cap on right. they reset it for me but came on again week later and then wanted to charge me to check codes again. they did it first time for free. plz help me!
Old Aug 14, 2012 | 08:23 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
http://www.obd-codes.com/trouble_codes/
Old Aug 14, 2012 | 10:29 AM
DodgeCares's Avatar
DodgeCares
Badone,
Here is the code description and possible causes on the P0456. I could not find code P0084 for a 2007 Durango.
P0456-EVAP PURGE SYSTEM SMALL LEAK
  • When Monitored: With the ignition off, fuel level less than 88%, ambient temperature between 4° C and 43° C (39° F and 109° F), and the fuel system in closed loop.
  • Set Condition: As temperatures change, a vacuum is created in the fuel tank and Evap system. With the Evap system sealed, the PCM monitors the ESM switch. If the ESM switch does not close within a calibrated time, an error is detected by the PCM. One Trip Fault. Three good trips to turn off the MIL.
Possible Causes
EVAP PURGE SYSTEM LEAK
EVAP PURGE SOLENOID
EVAP SYSTEM MONITOR SWITCH
Old Aug 14, 2012 | 04:51 PM
badone45's Avatar
badone45
Ok ty i double checked that poo84 code. sorry my bad its suppose to be 0884? so is that evap leak something i shuld get checked out asap or can it wait, just as finances are tight at the moment for me.. ty
Old Aug 15, 2012 | 09:47 AM
DodgeCares's Avatar
DodgeCares
Hopefully someone else will chime in on the EVAP leak as I cannot give advice on if you should fix it or not. I will say that if you do not fix it just keep in mind if that was the cause of the check engine light to be on that the light will continue to stay on. If the light stays on you will not know of other conditions that may arise that you would normally be alerted to when the light would come on since it is always on. Any auto parts store will typically read the codes for you for free along with many oil change places. My advice would be that if you do not fix the EVAP leak and the light stays on just have the codes read once in awhile to make sure additional codes are not popping up.
As far as the P0884 code, the description is below.
Theory of Operation
If a vehicle loses power to the Transmission Control System, the solenoids (L/R, 2C, OD, UD, 4C) will go to their respective power off state. Some solenoids are normally vented and some are normally applied in their power off state. The transmission is designed to be in 3rd gear with all of the solenoids in this state. However, if power is restored, the Transmission Control System will power-up and normal operation will be restored.
This code identifies that power to the Transmission Control System was restored when the gear selector was in a "Drive" position while the vehicle was moving at speeds above 32 km/h (20 mph). This DTC does not indicate a problem with the transmission or Transmission Control System, instead, it suggests intermittent problems in the fused ignition switch output, fused B(+), or ground circuits to the TCM. Alternately, if a person performs a rolling restart maneuver, the DTC can be set. Therefore it is critical that this DTC be investigated if the vehicle is experiencing intermittent 3rd gear operation and a subsequent return to normal operation.
  • When Monitored: When Powertrain Control Module initially powers up. Due to the integration of the Powertrain and Transmission Control Modules, the transmission part of the PCM has its own specific power and ground circuits.
  • Set Condition: This DTC will set if the PCM powers up and senses the vehicle in a valid forward gear, with no PRNDL DTCs, and an output speed above 800 rpm, approximately 32Km/h or 20 mph.
Possible Causes
POWER UP AT SPEED
Old Aug 16, 2012 | 09:25 PM
badone45's Avatar
badone45
Ok. tyvm for your info was very helpful. The truck doesnt seem to have any problems shift. seems to shift smooth cant even feel it shift at all. but i did have an accident the other day i was drivin to friends house and accidently hit the key and truck shut off when i was driving. i wonder if that wuld be the cause to turn that code on?
Old Aug 17, 2012 | 07:57 AM
DodgeCares's Avatar
DodgeCares
It's possible that was the cause. Clear the codes and see if anything other than the EVAP leak code comes back on.
Old Aug 18, 2012 | 12:22 PM
badone45's Avatar
badone45
ok ty you have been very helpful and i will try that.
Old Aug 21, 2012 | 12:43 PM
stagehand702's Avatar
stagehand702
Default 2007 Durango 4.7L flex fuel 4wd
Help- I was coming home from work the other night @ 70mph- when the whole engine cut off- took me about 4x to re-start it, next day, tookit to AutoZone-and they ran a diagnostic check-OEM Number to cross P2074 is the code that came up- it lists
DEFINITION-manifold pressure/throttle position correlation- high flow/vacuum leak
EXPLANATION- ECM has detected a failed signal correlation between the MAP and TPS
PROBABLE CAUSE-1)Large vacuum leak on the engine; 2)engine mechanical condition; 3)Failed MAP sensor; 4)TP sensor fault
Anyone know how to pinpoint the determination of the issue on whether it could be the MAP sensor or the TP sensor without having to spend a boatload of dough on these parts, and then find out if it's something else entirely? any help would be greatly appreciated...
STUCK IN VEGAS WITHOUT WHEELS
