Clockspring Air bag light
Guys, question.
I had an intermittent air bag light (dash not passenger side) for a few months. It finally stayed on, and now it won't shut off.
I've read quite a bit about it and all the posts I've read suggest that its probably the clock spring. I've also read that if it is the clockspring other things such as the stereo controls on the steering wheel and the cruise control fail as well. Well in my case these are working fine. I really don't want to spend 4-5 hours removing the steering wheel and all the components and replacing the clock spring if this might not be the problem.
Has anyone had the same issue with the clockspring being bad while the other controls are working?
Thanks for any help
rr
2004 LTD Hemi
Thanks for any help
rr
2004 LTD Hemi
THe 2004 is palgued wuith problems that led to many recalls. Go to safercar.gov and fill in your vehicles parameters for details. You dealer (or any dealer) will need your VIN to see if they affect your vehicle and if they were performed:
ake: DODGE Model: DURANGO
Model Year: 2004
Manufacturer: DAIMLERCHRYSLER CORPORATION Mfr's Report Date: DEC 12, 2003
NHTSA CAMPAIGN ID Number: 03V528000 NHTSA Action Number: N/A
Component: ELECTRICAL SYSTEM:WIRING:INTERIOR/UNDER DASH
Potential Number of Units Affected: 27,586
Summary:
ON CERTAIN SPORT UTILITY VEHICLES, AN INSTRUMENT CLUSTER CIRCUIT BOARD CAPACITOR MAY OVERHEAT.
Consequence:
THIS COULD POTENTIALLY RESULT IN AN INSTRUMENT PANEL FIRE.
Remedy:
DEALERS WILL REMOVE THE CAPACITOR FROM THE CIRCUIT BOARD. OWNER NOTIFICATION BEGAN ON DECEMBER 17, 2003. OWNERS SHOULD CONTACT DAIMLERCHRYSLER AT 1-800-992-1997.
Notes:
DAIMLERCHRYSLER RECALL NO. C43. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Check to Request Research. Submit below.
Make: DODGE Model: DURANGO
Model Year: 2004
Manufacturer: DAIMLERCHRYSLER CORPORATION Mfr's Report Date: JAN 13, 2004
NHTSA CAMPAIGN ID Number: 04V020000 NHTSA Action Number: N/A
Component: VEHICLE SPEED CONTROL:CABLES
Potential Number of Units Affected: 21,053
Summary:
ON CERTAIN SPORT UTILITY VEHICLES EQUIPPED WITH 3.7L AND 4.7L ENGINES, THE THROTTLE CONTROL CABLE MAY INGEST WATER AND FREEZE DURING EXTENDED COLD TEMPERATURE.
Consequence:
THIS COULD CAUSE THE THROTTLE TO STICK IN THE OPEN POSITION AND RESULT IN A CRASH.
Remedy:
DEALERS WILL REPLACE THE THROTTLE CONTROL CABLE. OWNER NOTIFICATION BEGAN ON JANUARY 19, 2004. OWNERS SHOULD CONTACT DAIMLERCHRYSLER AT 1-800-853-1403.
Notes:
DAIMLERCHRYSLER RECALL NO. D02. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Model Year: 2004
Manufacturer: DAIMLERCHRYSLER CORPORATION Mfr's Report Date: DEC 07, 2004
NHTSA CAMPAIGN ID Number: 04V578000 NHTSA Action Number: N/A
Component: ELECTRICAL SYSTEM:BATTERY:CABLES
Potential Number of Units Affected: 71,763
Summary:
ON CERTAIN SPORT UTILITY VEHICLES BUILT WITH A 5.7L, 4.7L, OR 3.7L ENGINE, THE POSITIVE BATTERY CABLE MAY CONTACT THE FRONT SUSPENSION UPPER CONTROL ARM MOUNTING BRACKET.
Consequence:
THIS CONTACT COULD ABRADE THE CABLE AND CAUSE A SHORT CIRCUIT, WHICH MAY RESULT IN AN UNDERHOOD FIRE.
Remedy:
DEALERS WILL INSPECT THE BATTERY CABLE AND, IF NECESSARY, REPOSITION IT AWAY FROM THE CONTROL ARM MOUNTING BRACKET. THE RECALL BEGAN DECEMBER 14, 2004. OWNERS SHOULD CONTACT DAIMLERCHRYSLER AT 1-800-853-1403.
Notes:
DAIMLERCHRYSLER RECALL NO. D40. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Model Year: 2004
Manufacturer: DAIMLERCHRYSLER CORPORATION Mfr's Report Date: MAR 06, 2007
NHTSA CAMPAIGN ID Number: 07V092000 NHTSA Action Number: EA06015
Component: ELECTRICAL SYSTEM: INSTRUMENT PANEL
Summary:
ON SOME SPORT UTILITY VEHICLES, UNDER CERTAIN OPERATING CONDITIONS, AN INTEGRATED CIRCUIT IN THE INSTRUMENT CLUSTER THAT CONTROLS INTERIOR LIGHTING MAY OVERHEAT.
Consequence:
THIS COULD POTENTIALLY CAUSE AN INSTRUMENT PANEL FIRE.
Remedy:
DEALERS WILL INSPECT THE CLUSTER FOR DAMAGE AND REPLACE IT FREE OF CHARGE. THE RECALL BEGAN ON APRIL 2, 2007. OWNERS MAY CONTACT DAIMLERCHRYSLER AT 1-800-853-140.
Notes:
DAIMLERCHRYSLER RECALL NO. G07. CUSTOMERS MAY CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY: 1-800-424-9153); OR GO TO HTTP://WWW.SAFERCAR.GOV.
Model Year: 2004
Manufacturer: SABERSPORT Mfr's Report Date: MAR 28, 2009
NHTSA CAMPAIGN ID Number: 09E012000 NHTSA Action Number: N/A
Component: EXTERIOR LIGHTING
Summary:
SABERSPORT IS RECALLING 16,270 COMBINATION CORNER AND BUMPER LAMP ASSEMBLIES OF VARIOUS PART NUMBERS SOLD FOR USE AS AFTERMARKET EQUIPMENT FOR VARIOUS PASSENGER VEHICLES. THESE HEADLAMPS FAIL TO CONFORM TO THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 108, "LAMPS, REFLECTIVE DEVICES, AND ASSOCIATED EQUIPMENT." THESE LAMPS DO NOT CONTAIN THE REQUIRED AMBER SIDE REFLECTORS.
Consequence:
DECREASED LIGHTING VISIBILITY MAY RESULT IN A VEHICLE CRASH.
Remedy:
SABERSPORT WILL NOTIFY OWNERS AND OFFER A FULL REFUND FOR THE NONCOMPLIANT COMBINATION LAMPS. THE SAFETY RECALL BEGAN ON MAY 11, 2009. OWNERS MAY CONTACT SABERSPORT AT 1-909-598-7589.
Notes:
THIS RECALL ONLY PERTAINS TO AFTERMARKET REPLACEMENT EQUIPMENT AND HAS NO RELATION TO ANY ORIGINAL EQUIPMENT INSTALLED ON VEHICLES PRODUCED BY THE VEHICLE MANUFACTURER. IN ORDER TO DETERMINE IF YOUR AFTERMARKET LAMP ASSEMBLY IS AFFECTED BY THIS NONCOMPLIANCE, PLEASE REVIEW THE LIST OF MODEL NUMBERS PROVIDED TO US BY SABERSPORT. THE LIST CAN BE FOUND UNDER "DOCUMENT SEARCH" LOCATED AT THE BOTTOM OF YOUR SCREEN. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
Model Year: 2004
Summary:
Consequence:
Remedy:
Notes:
Model Year: 2004
Summary:
Consequence:
Remedy:
Notes:
Model Year: 2004
Summary:
Consequence:
Remedy:
Notes:
Model Year: 2004
Summary:
Consequence:
Remedy:
Notes:
Model Year: 2004
Summary:
Consequence:
Remedy:
Notes:
Guys, question.
Thanks for any help
rr
2004 LTD Hemi
Thanks for any help
rr
2004 LTD Hemi
If you PM me the Vin I can tell you what recalls your vehicle may have had and if any still need to be performed.
