2nd Gen Durango 2004 - 2009
3 issues with 2008 5.7 hemi
Old Sep 2, 2012 | 03:19 AM
7o7o's Avatar
7o7o
Default 3 issues with 2008 5.7 hemi
I bought a 2008 durango 5.7 hemi one year ago, it is such an amazing ride.... but things started to pop up... got 3 different issues i need help with...
1- Remote starter key won't function from a distance, i have to be really close to the car and press as hard as i can on the key... i already tried 2 different batteries for the key...
2- I hear a clicking sound coming from the bottom of the car on sharp & fast turns... no clue what is that, i'm sure its not from the tires and also not from the front part of the car.
3- The rear left tire pressure sensor isn't giving any reading, can it be fixed or do i have to replace it ? would there be any issues driving with the tiris warning lights on ??
Thnx guys for the help.... much appreciated
Old Sep 3, 2012 | 12:18 AM
PokerMunkee's Avatar
PokerMunkee
1. Do you have two fobs? Do both of them do this? My OEM remote start works quite a ways. Is your remote start fob seperate from the main key or part of it?
2. Not sure
3. If it's a bad sensor, you can get them replaced at Walmart for $50 plus the cost of dismounting the tire and rebalancing it. Won't hurt anything with the TPMS sensor on.
Old Sep 3, 2012 | 02:17 AM
7o7o's Avatar
7o7o
1- nope... only got 1 key...
2- the damn clicks are so annoying, botton click at fast & sudden corners
3- will do that after pay day
thnx buddy
Old Sep 23, 2012 | 05:36 AM
7o7o's Avatar
7o7o
update update...
1- the key issue is now sorted... worked perfectly few days later without doing any work on it...
2- Seems i was a bit wrong, the sound is coming from the front part when doing hard turn, and also if i floor the throttle from a dead stop, also if braking hard... any one has a clue ?? would it be the engine mounts ??
3- warning signals are off now, sensor working fine... all by itself
