2nd Gen Durango 2004 - 2009
Rain Rain Rain
Old Sep 5, 2012 | 11:14 PM
lholder's Avatar
lholder
Default Rain Rain Rain
So it started raining tonight, and i,not knowing it was gonna rain, left the sunroof on my 04 durango open. when i came outside to shut it, the inside had gotten pretty wet. i dried everything off but after driving home the check engine light came on and a bunch of codes relating to the electronics in the dash came on and it started running rough. i'm hoping that once it dries out (i've got a fan running on it) everything will work. Any suggestions?
Old Sep 6, 2012 | 11:15 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
The 2004 has numerous recalls that may be at fault along with the rain. Call your dealer and they will need your VIN to see if your vehicle is affected:
www.safercar.gov
Make: DODGE Model: DURANGO
Model Year: 2004
Manufacturer: DAIMLERCHRYSLER CORPORATION Mfr's Report Date: DEC 12, 2003
NHTSA CAMPAIGN ID Number: 03V528000 NHTSA Action Number: N/A
Component: ELECTRICAL SYSTEM:WIRING:INTERIOR/UNDER DASH
Potential Number of Units Affected: 27,586
Summary:
ON CERTAIN SPORT UTILITY VEHICLES, AN INSTRUMENT CLUSTER CIRCUIT BOARD CAPACITOR MAY OVERHEAT.
Consequence:
THIS COULD POTENTIALLY RESULT IN AN INSTRUMENT PANEL FIRE.
Remedy:
DEALERS WILL REMOVE THE CAPACITOR FROM THE CIRCUIT BOARD. OWNER NOTIFICATION BEGAN ON DECEMBER 17, 2003. OWNERS SHOULD CONTACT DAIMLERCHRYSLER AT 1-800-992-1997.
Notes:
DAIMLERCHRYSLER RECALL NO. C43. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Check to Request Research. Submit below.
Model Year: 2004
Manufacturer: DAIMLERCHRYSLER CORPORATION Mfr's Report Date: JAN 13, 2004
NHTSA CAMPAIGN ID Number: 04V020000 NHTSA Action Number: N/A
Component: VEHICLE SPEED CONTROL:CABLES
Potential Number of Units Affected: 21,053
Summary:
ON CERTAIN SPORT UTILITY VEHICLES EQUIPPED WITH 3.7L AND 4.7L ENGINES, THE THROTTLE CONTROL CABLE MAY INGEST WATER AND FREEZE DURING EXTENDED COLD TEMPERATURE.
Consequence:
THIS COULD CAUSE THE THROTTLE TO STICK IN THE OPEN POSITION AND RESULT IN A CRASH.
Remedy:
DEALERS WILL REPLACE THE THROTTLE CONTROL CABLE. OWNER NOTIFICATION BEGAN ON JANUARY 19, 2004. OWNERS SHOULD CONTACT DAIMLERCHRYSLER AT 1-800-853-1403.
Notes:
DAIMLERCHRYSLER RECALL NO. D02. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Model Year: 2004
Manufacturer: DAIMLERCHRYSLER CORPORATION Mfr's Report Date: DEC 07, 2004
NHTSA CAMPAIGN ID Number: 04V578000 NHTSA Action Number: N/A
Component: ELECTRICAL SYSTEM:BATTERY:CABLES
Potential Number of Units Affected: 71,763
Summary:
ON CERTAIN SPORT UTILITY VEHICLES BUILT WITH A 5.7L, 4.7L, OR 3.7L ENGINE, THE POSITIVE BATTERY CABLE MAY CONTACT THE FRONT SUSPENSION UPPER CONTROL ARM MOUNTING BRACKET.
Consequence:
THIS CONTACT COULD ABRADE THE CABLE AND CAUSE A SHORT CIRCUIT, WHICH MAY RESULT IN AN UNDERHOOD FIRE.
Remedy:
DEALERS WILL INSPECT THE BATTERY CABLE AND, IF NECESSARY, REPOSITION IT AWAY FROM THE CONTROL ARM MOUNTING BRACKET. THE RECALL BEGAN DECEMBER 14, 2004. OWNERS SHOULD CONTACT DAIMLERCHRYSLER AT 1-800-853-1403.
Notes:
DAIMLERCHRYSLER RECALL NO. D40. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Model Year: 2004
Manufacturer: DAIMLERCHRYSLER CORPORATION Mfr's Report Date: MAR 06, 2007
NHTSA CAMPAIGN ID Number: 07V092000 NHTSA Action Number: EA06015
Component: ELECTRICAL SYSTEM: INSTRUMENT PANEL
Summary:
ON SOME SPORT UTILITY VEHICLES, UNDER CERTAIN OPERATING CONDITIONS, AN INTEGRATED CIRCUIT IN THE INSTRUMENT CLUSTER THAT CONTROLS INTERIOR LIGHTING MAY OVERHEAT.
Consequence:
THIS COULD POTENTIALLY CAUSE AN INSTRUMENT PANEL FIRE.
Remedy:
DEALERS WILL INSPECT THE CLUSTER FOR DAMAGE AND REPLACE IT FREE OF CHARGE. THE RECALL BEGAN ON APRIL 2, 2007. OWNERS MAY CONTACT DAIMLERCHRYSLER AT 1-800-853-140.
Notes:
DAIMLERCHRYSLER RECALL NO. G07. CUSTOMERS MAY CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY: 1-800-424-9153); OR GO TO HTTP://WWW.SAFERCAR.GOV.
Model Year: 2004
Manufacturer: SABERSPORT Mfr's Report Date: MAR 28, 2009
NHTSA CAMPAIGN ID Number: 09E012000 NHTSA Action Number: N/A
Component: EXTERIOR LIGHTING
Summary:
SABERSPORT IS RECALLING 16,270 COMBINATION CORNER AND BUMPER LAMP ASSEMBLIES OF VARIOUS PART NUMBERS SOLD FOR USE AS AFTERMARKET EQUIPMENT FOR VARIOUS PASSENGER VEHICLES. THESE HEADLAMPS FAIL TO CONFORM TO THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 108, "LAMPS, REFLECTIVE DEVICES, AND ASSOCIATED EQUIPMENT." THESE LAMPS DO NOT CONTAIN THE REQUIRED AMBER SIDE REFLECTORS.
Consequence:
DECREASED LIGHTING VISIBILITY MAY RESULT IN A VEHICLE CRASH.
Remedy:
SABERSPORT WILL NOTIFY OWNERS AND OFFER A FULL REFUND FOR THE NONCOMPLIANT COMBINATION LAMPS. THE SAFETY RECALL BEGAN ON MAY 11, 2009. OWNERS MAY CONTACT SABERSPORT AT 1-909-598-7589.
Notes:
THIS RECALL ONLY PERTAINS TO AFTERMARKET REPLACEMENT EQUIPMENT AND HAS NO RELATION TO ANY ORIGINAL EQUIPMENT INSTALLED ON VEHICLES PRODUCED BY THE VEHICLE MANUFACTURER. IN ORDER TO DETERMINE IF YOUR AFTERMARKET LAMP ASSEMBLY IS AFFECTED BY THIS NONCOMPLIANCE, PLEASE REVIEW THE LIST OF MODEL NUMBERS PROVIDED TO US BY SABERSPORT. THE LIST CAN BE FOUND UNDER "DOCUMENT SEARCH" LOCATED AT THE BOTTOM OF YOUR SCREEN. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
