2nd Gen Durango 2004 - 2009
Power Outlet Fuse Help
Old Sep 17, 2012 | 01:56 PM
meric327's Avatar
meric327
Default Power Outlet Fuse Help
I need help locating the fuser for the middle center console power port. I found the one to the cigarette lighter under the dash and my Rear power port is working, however the middle center console one is not.
Where is it located? Under the hood, in the kick dash panel, also what fuse is it?
2008 Dodge Durango, 4X4 Limited
Last edited by meric327; Sep 17, 2012 at 01:58 PM. Reason: Forgot to Add Year Make Model of Car.
Old Sep 17, 2012 | 06:58 PM
PokerMunkee's Avatar
PokerMunkee
It's in the driver side kick panel (inside).
The 20a fuse in the very top right is for the power outlet in the dash.
The 20a fuse smack dab in the middle is for the center console outlet (between driver and passenger seat). There is two positions for this fuse, so you can have power on when vehicle is off or only power when vehicle is on.
Even if the fuse looks good, replace it. I had the same problem.
At least this is how it is with my 2007. Hopefully this helps.
