2nd Gen Durango 2004 - 2009
Water leak
Old Oct 5, 2012 | 05:21 AM
jmoxham's Avatar
jmoxham
Default Water leak
Hi,
Am a new Durango owner (this week!) - 2006 4wd 5.7 hemi - and have a water leak from a little stubby pipe on the passenger side behind the engine.
I wonder if this is an expansion tank for the coolant and is ok to leak or whether this might be a problem..? Here it is about 100 degrees today by the way!
Also wondered of there are any standard mods for improving a choppy ride - recommendations fro new springs/shocks at all?
Many thanks!
Old Oct 5, 2012 | 08:55 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
I like Bilstein for shocks, but KYB are decent.
FF
Old Oct 5, 2012 | 09:58 AM
DodgeCares's Avatar
DodgeCares
Originally Posted by jmoxham
Hi,
Many thanks!
Jmoxham,
What did the "leak" fluid look like? Was it coolant or simply condensation(water) from the A/C being used?
Old Oct 5, 2012 | 02:07 PM
jmoxham's Avatar
jmoxham
Thanks for the replies, re shocks and the source of the leak.
The fluid seemed to be clear, had not considered that it may be AC condensation..!
It was leaking from a stubby little black pipe behind the passenger front wheel area..
Old Oct 5, 2012 | 02:15 PM
DodgeCares's Avatar
DodgeCares
When the car is cool you may want to check the coolant level just in case but the next time you notice the fluid dripping, try turning off the A/C and see if it stops.
Old Oct 5, 2012 | 02:40 PM
jmoxham's Avatar
jmoxham
Great, many thanks for the advice!
