window switches not working
i took each door panel off and made sure each motor works with a seperate battery.then i took all the switches out of 2005 durango and tried them in the 04 and nope the didn't work. so i took all the 04 switches and tried them in the 05 and they work fine so the switches are good. i did check all the fuses and they all look good. not sure on what else to check for and where to look does anyone have any ideas
thank you
thank you
