2nd Gen Durango 2004 - 2009
04 durango problem
Old Oct 9, 2012 | 01:34 PM
Jawint01's Avatar
Jawint01
Default 04 durango problem
Driving to work and my check engine came on. At first I didn't notice anything wrong, then as the stop light turned green, I stepped on the gas and it felt like I was starting off in second gear. It doesn't have any odd sound but a major loss of power. Feels like I am pulling a heavy trailer.
Thanks
5.7 litre 4x4/awd
Old Oct 9, 2012 | 03:48 PM
extremis's Avatar
extremis
You'll need to get the codes checked. Could be anything. Bad sensor, transmission, bad fuel, electrical...
Old Oct 9, 2012 | 07:31 PM
Jawint01's Avatar
Jawint01
Default Codes
Just had codes ran
P0700-transmission control system(malfunction indicator lamp request)
P2706-shift solenoid "F"
Anyone know how to fix this or what to do??
Old Oct 16, 2012 | 05:52 PM
extremis's Avatar
extremis
Not sure, but to me this sounds like your transmission is stuck in "limp" mode.
The codes indicate the shift solenoid. This could be the solenoid itself, or a wiring issue. Last time I had this type of issue, the vehicle was under warranty and I took it for repair. Turned out to be a bad connection. I can't be much more help as I haven't worked on this type of problem as yet. If you know a good transmission guy, that would be the place to start though.
