2nd Gen Durango 2004 - 2009
2007 durango trans slip?
Old Nov 3, 2012 | 11:10 AM
makosnax's Avatar
makosnax
Default 2007 durango trans slip?
when cruising over 60mph the rpms will surge as if the trans is switching between overdrive and third gear. switched into tow haul mode and truck does the same thing. Any ideas? fluid level is clean and correct. almost seems electronic. sorry for the underline cant seem to turn it off lol there we go thanks in advance
Old Nov 3, 2012 | 06:42 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
You may have 5 gears and mine did this and a code for 'can not find gear' popped up. $3200.00 for a rebuild.
FF
