2nd Gen Durango 2004 - 2009
Aftermarket Key Fob
Old Dec 4, 2012 | 07:12 PM
jethroish's Avatar
jethroish
Default Aftermarket Key Fob
Just bought a 2004 Durango, only 46,000 original miles. Got 3 keys, but on of them, the remote buttons do not work, Yes, I tried replacing battery.
Too cheap to spend $150 at the stealer for a new key/fob.
Anyone know where to get aftermarket FOB cheap that will work. The Durango has aftermarket Viper remote start. The Viper FOB works for lock/unlock so I know there are some FOBs out there that will work. Like I said, too cheap to spend a lot of $$. I'd rather just put the key in the door if I have to.
I know, if I have 2 that work, what does it matter. Well, wife has one and daughter has the other.
Thanks
Old Dec 5, 2012 | 12:15 PM
btallon's Avatar
btallon
New Member
You might want to try re-soldering the metal clip that holds the battery in. On both my 04 Durango key fobs the clip had a bad connection and some solder fixed the problem.Name:  IMG_20121205_121743.jpg
Old Dec 5, 2012 | 03:26 PM
jethroish's Avatar
jethroish
btallon,
Thanks for that info. I looked at the questionable FOB and it does look like that solder is broke. Gonna try to add a small drop.
Old Dec 8, 2012 | 10:23 PM
jethroish's Avatar
jethroish
Added a drop of solder. No go.
Old Dec 10, 2012 | 02:01 PM
btallon's Avatar
btallon
New Member
Bummer, might be bad then I guess. I just had to resolder mine again a few weeks ago.
Someone else mentioned having a dealer test them in another thread.
Good Luck.
