2nd Gen Durango 2004 - 2009
adding receiver hitch. which one?
Old Dec 11, 2012 | 03:31 PM
jethroish's Avatar
jethroish
Default adding receiver hitch. which one?
2004 Durango ST 4x4.
I want to add a hitch. I see there are a couple different kinds. What is the the best and/or easiest to install?
Old Dec 12, 2012 | 09:29 AM
DodgeCACares's Avatar
DodgeCACares
Jethroish,
I would suggest the Mopar brand as they are designed specifically for Dodge products. Check out the options and information at the link below.
http://www.mopar.com/dodge/durango/2...2321/274/4953/
I hope this helps.
Old Dec 12, 2012 | 05:06 PM
extremis's Avatar
extremis
As an FYI, the Durango without tow package is only rated to tow 2000lbs max even when adding an appropriate after market hitch. This comes from the owner manual.
Old Mar 2, 2014 | 12:36 PM
jethroish's Avatar
jethroish
Finally getting around to doing this. I have the factory Tow Package just no receiver.
Just not sure if it is better to go with the frame mounted or the bumper mounted. Either is rated high enough for my needs. Basically comes down to ease of installation.
