2nd Gen Durango 2004 - 2009
Need help Dodge Durango SLT
Old Jan 15, 2013 | 12:21 AM
moftah's Avatar
moftah
Unhappy Need help Dodge Durango SLT
I have Dodge Durango SLT he don't work so I buy cable elm327 and install software scan-pro and he check and he give me Error Code U1403
please I need help
Old Jan 15, 2013 | 01:22 AM
go-part's Avatar
go-part
Former Vendor
U1403-IMPLAUSIBLE FUEL LEVEL SIGNAL RECEIVED
When Monitored:
Ignition on.
Set Condition:
The fuel volume message the ECM is receiving is implausible. The circuit is continuously monitored. One Trip fault.
Possible Causes
CAN B OPEN OR SHORTED
CLUSTER MODULE
TOTALLY INTEGRATED POWER MODULE (TIPM)
ECM
Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 9 - ENGINE - DIAGNOSIS AND TESTING).
Theory of Operation
The Totally Integrated Power Module isn't receiving a fuel volume signal over CAN B from the Cluster Module. The TIPM has to send the PCM a fuel volume signal over CAN C. The signal the TIPM sends over CAN C is implausible.
Diagnostic Test
1. ACTIVE DTC
Ignition on, engine not running.
With a scan tool read DTCs.
Is the DTC Active at this time?
Yes
Go To 2
No
Refer to the INTERMITTENT CONDITION Diagnostic Procedure.
2. CAN B BUS HARDWARE DTCS ALSO ACTIVE
With a scan tool check for DTCs in the FCM (TIPM).
Are any CAN B Hardware related DTCs active at this time?
Yes
(Refer to 8 - ELECTRICAL/ELECTRONIC CONTROL MODULES - DIAGNOSIS AND TESTING) for the appropriate diagnostic procedures.
Perform BODY VERIFICATION TEST – VER 1.
No
Replace and program the Powertrain Control Module per Service Information.
Perform the POWERTRAIN VERIFICATION TEST. (Refer to 9 - ENGINE - STANDARD PROCEDURE)
This sounds like your problem
Old Jan 15, 2013 | 02:02 AM
moftah's Avatar
moftah
thank you help me but I have same questions
You say 2. CAN B BUS HARDWARE DTCS ALSO ACTIV...what good device Recommend to buy it..
Same people Some people specialize in car mechanics tells me the problem is Immo lock and you needing to cleaner so I have same programs but I didn't how to use and what the device I needed
Thank you
Old Jan 15, 2013 | 09:21 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
https://dodgeforum.com/forum/dodge-d...s-section.html
need much more information on the vehicle, mostly year and engine and driveline
Old Jan 24, 2013 | 12:14 AM
moftah's Avatar
moftah
dodge durango slt 2007
like this
http://www.edmunds.com/dodge/durango/2007/
where I can Found number Year engine and driveline?
Old Jan 29, 2013 | 05:19 PM
shrpshtr325
THE ULTI-MOD
year is 2007, model is durango, (i have moved this to the correct section, these guys will be able to help you)
the guys here in the 2nd generation section should be able to help acquire the rest of the information that they need to help you
