2 Problems: Gascap light and Gas Spits back out at pump
I have a 2007 4.7L durango.
For several months now I have a check engine light that comes on with the word GasCap on the LCD Screen. I have replaced the gascap and reset the error, but it still comes back.
Also, since we have owned the vehicle(little over a year now) when filling up at the gas pump, some pumps will shut off fine and there is no spray out, but most pumps when they shut off, a second or two later gas is spilling out. I have see that this is a common issue with the durango, but haven't seen any solutions as of yet.
Are these two items part of the same issue or separate ones?
Thank you in advance for any help you can offer.
Steve
Steve
Steve
Steve
Below is the TSB on the extended warranty for the inlet check valve. If you want to PM me your vin I will make sure it applies to your vehicle.
NUMBER: 14-001-12 REV. A
GROUP: Fuel System
DATE: April 19, 2012
THIS BULLETIN SUPERSEDES SERVICE BULLETIN 14-001-12, DATED JANUARY 20,
2012, WHICH SHOULD BE REMOVED FROM YOUR FILES. THIS IS A COMPLETE
REVISION AND NO ASTERISKS HAVE BEEN USED TO HIGHLIGHT REVISIONS.
SUBJECT:
Fuel Spit Back During Refueling Due To Inlet Check Valve X39 (Unlimited Time And
Mileage Warranty Extension)
OVERVIEW:
This bulletin involves replacing the fuel filler tube if the condition occurs.
NOTE: When removing the existing fuel filler tube note how it comes out to aid in
installation of the new part.
MODELS:
2006 - 2008 (HB) Durango
2007 - 2008 (HG) Aspen
NOTE: This Extended Warranty Bulletin applies to HB vehicles equipped with a
naturally aspirated gasoline engine built between February 1, 2006 (MDH
0201XX) and March 31, 2008 (MDH 0331XX) or HG vehicles equipped with a
naturally aspirated gasoline engine built before April 1, 2008 (MDH 0401XX).
SYMPTOM/CONDITION:
Some customers may experience a fuel spit back condition during a refueling event.
DIAGNOSIS:
If the customer experiences the symptom/condition, proceed to the repair procedure.
My VIN is : 1D8HB48N67FXXXXXX
Thank you,
Steve
Thank you,
Steve
Steve,
GROUP: Fuel System
SUBJECT:
OVERVIEW:
MODELS:
SYMPTOM/CONDITION:
DIAGNOSIS:
GROUP: Fuel System
SUBJECT:
OVERVIEW:
MODELS:
SYMPTOM/CONDITION:
DIAGNOSIS:
