2nd Gen Durango 2004 - 2009
AWD noise question
Old Mar 13, 2013 | 10:20 PM
DBro1325's Avatar
DBro1325
Default AWD noise question
Howdy gents, new to the forum and have a question about my D. Its a 2007 AWD 4.7 , when power goes to the front end after rear tire slipage, should it sound just like ABS sounds? Just sounds weird, any helpwould be appriciated. Thanks in advance.
Old Mar 14, 2013 | 07:55 AM
DodgeCares's Avatar
DodgeCares
DBro,
It sounds like what you are describing is the Electronic Stability Program kicking in.Does the ESP/TCS light up on the dash when this happens? If so that is what you are feeling. Below is a description. Welcome to the forum.
ESP (Electronic Stability Program)
This system enhances directional control and stability of
the vehicle under various driving conditions. ESP corrects
for over/under steering of the vehicle by applying
the brake of the appropriate wheel to assist in counteracting
the over/under steer condition. Engine power
may also be reduced to help the vehicle maintain the
desired path.
ESP uses sensors in the vehicle to determine the vehicle
path intended by the driver and compares it to the actual
path of the vehicle. When the actual path does not match
the intended path, ESP applies the brake of the appropriate
wheel to assist in counteracting the oversteer or
understeer condition.
• Oversteer - when the vehicle is turning more than
appropriate for the steering wheel position.
• Understeer - when the vehicle is turning less than
ESP/TCS Indicator Light
The ESP/TCS Indicator Light starts to flash as
soon as the tires lose traction and the TCS or
ESP system becomes active. It will also flash
once a swaying trailer is detected and the TSC
(Trailer Sway Control) system activates. If the ESP/TCS
Indicator Light begins to flash during acceleration, ease
up on the accelerator and apply as little throttle as
possible. Be sure to adapt your speed and driving to the
prevailing road conditions.
