2nd Gen Durango 2004 - 2009
05 dodge Durango
Old Mar 18, 2013 | 12:25 AM
butchhyer's Avatar
butchhyer
Default 05 dodge Durango
I'm having a problem with my Durango not starting sometimes it will crank over and start every time and then it will just click, or it will start to turn over then stop. When it does this I have found that sometimes when you hit the key in it will start. I have replaced the starter and the ignition switch. It is almost like it is losing a connection somewhere, but it will work fine for a while then act up a few times. Any thoughts out there would be much appreciated thank you
Old Mar 19, 2013 | 05:56 PM
go-part's Avatar
go-part
Former Vendor
Have you had the battery and alternator tested?
How old is the battery and alternator?
Old Mar 19, 2013 | 09:32 PM
butchhyer's Avatar
butchhyer
The battery and alternator check out fine. I have also notice that every time I take the steering column apart to lock for a bad connection and put it back together it starts just fine for a few days and then it starts acting up again. I am at a loss of where to look next.
