2nd Gen Durango 2004 - 2009
Engine Issues!
Old Apr 27, 2013 | 08:44 PM
RobertStyers's Avatar
RobertStyers
Default Engine Issues!
I recently received a letter from Chrysler saying that my check valve in my 2005 Dodge Durango's fuel tank needed replaced so I took the vehicle to the dealer and had them replace it. Everytime I would fill up with fuel the fuel would come shooting back out. After they fixed the issue the vehicle ran fine for a day then the check engine light came and the vehicle stalled on the road. I took the vehicle to autozone and had them check the codes. Here are the codes that were given: P061C (electronic throttle control ETC level 2 RPM), P0300 (cylinder misfire detected-random cylinders), P0315 (crank sensor condition) , and p0340 (cam sensor condition). If they got something into my fuel system or if installed the part wrong would it cause these codes?
Old Apr 28, 2013 | 05:50 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
I would have a mechanic (not the dealer) look at it and I would assume the codes are not related to the gas tank purging fuel.
FF
Old Apr 29, 2013 | 09:38 PM
RobertStyers
If you had to say what would you think it could be?
Old Apr 30, 2013 | 02:42 PM
1969CoronetR/T
vaffanculo
Maybe water getting into the coil packs because of the cowl being defective.
