2nd Gen Durango 2004 - 2009
2004 Dodge Durango 5.7 stalled
Old Sep 20, 2013 | 03:01 PM
stephenlabb's Avatar
stephenlabb
Default 2004 Dodge Durango 5.7 stalled
I have a 2004 Dodge Durango, 5.7, I started the vehicle in the driveway and after a couple of minutes it stalled and will not start up. I checked the battery and it is good. When I turn the key to the starting position the check engine light will flash and stay on, also the check oil light stays on, the oil level is also good, could the issue be a bad oil sensor?
Old Sep 20, 2013 | 03:56 PM
How did you check your battery? Does it turn over but not start or just not turn over at all? Does the starter click? Need more specifics. The lights on the dash will come on when you turn the key on, just like when you start it.
Old Sep 20, 2013 | 05:08 PM
stephenlabb
Had the Battery checked at advanced auto, printout was good. The engine turns over but will not start, no clicking of starter, when I leave the key on and wait, the lights on the dash will turn off except check engine light and oil light, when I try to start the engine light and oil light stays on, it sounds like its going to start on the first try, but does not catch, I appreciate all of your help
Old Sep 20, 2013 | 05:16 PM
I will move this top the 2nd gen Durango section so those guys can help out. Good luck!
Old Sep 20, 2013 | 05:23 PM
stephenlabb
Thanks I appreciate your help
Old Sep 23, 2013 | 08:15 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
The 2004 has many recalls. Call a dealer with your VIN.
FF
Old Sep 24, 2013 | 11:48 AM
stephenlabb
Thanks!
