2nd Gen Durango 2004 - 2009
Electrical Issue / Battery Drain/ Radio Staying on
Old Dec 16, 2013 | 10:36 AM
keith s's Avatar
keith s
Default Electrical Issue / Battery Drain/ Radio Staying on
Hi all: My 2004 Hemi Durango is acting up. The battery is completely draining after several hours and the radio and accessory outlet is not shutting off after key is turned off and the driver door is opened. I have been manually shutting off the stereo and unplugging my fuzz buster but the drain continues. There was also a recent issue with the driver door lock not working but I was told that this was probably fixed now as we took the door panel off and it appeared that there was a loose connection to the door sensor which we secured back in place. I'm thinking I may need to bring it to a dealer to have them do an ignition-off draw test but the new issue with the stereo not turning off with the key off and the driver door opened seems suspicious. It also seems that the stereo and/or factory amp may be coming back on since I did come out to find my stereo on once even though I had turned it off. To complicate things further, I just had an aftermarket car starter put in... Has anyone ran across this issue(s)?
Old Dec 16, 2013 | 11:02 AM
keith s's Avatar
keith s
and now I see that my airbag lights are on (main and passenger side warning indicators)...
Old Dec 17, 2013 | 08:44 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
There are recalls on the 2004 for this problem. Call your dealer with your VIN o make sure all recalls have been addressed.
www.safercar.gov
Old Dec 18, 2013 | 02:29 PM
DodgeCACares's Avatar
DodgeCACares
Keith S,
Have you talked to a Dodge dealer to see if there are any outstanding recalls on the vehicle? If you want to confirm if there are any recalls or have any questions please feel free to PM me your VIN#.
Old Dec 18, 2013 | 11:41 PM
keith s's Avatar
keith s
There are not open recalls but the focus is now on the recent car starter installation. They are thinking that they tapped into a power source which is preventing the control module from going into sleep mode. The car starter guys are going to wire it direct to the battery to see if the control module starts going into sleep mode...Thx for the replies and I will provide an update once I figure out more.
Old Dec 21, 2013 | 03:09 PM
keith s's Avatar
keith s
Well, the problem seems to be fixed now. The remote car starter is now rewired directly to the battery and a faulty relay was replaced. The faulty relay seems to be the culprit as it was pulling 120 with the key off and everything powered down.
Old Dec 21, 2013 | 08:25 PM
1969CoronetR/T
vaffanculo
Thank you for the follow up.
FF
