2nd Gen Durango 2004 - 2009
Oil Light Flickering sometimes....
Old Mar 1, 2014 | 03:01 PM
Corwin613's Avatar
Corwin613
Default Oil Light Flickering sometimes....
So on thursday I took my 2005 Durango in for an oil change and there was build up so they did an top engine cleaning and oil change. As I left the oil light started going crazy so I took it back and they had me get the oil sensor replaced but the light was still going off so I went back and they did a total engine cleaning. The light was still going off at idle when the RPMs hit under 800. They said to drive it for a bit and bring it back if it didn't stop.
So later that day I started it up to warm up before work and it seemed to be fine so I drove it to work. I warmed it up after work and drove it home and it was fine until I stopped to get the mail and it was going off again.
I decided to wait and see if it was a fluke so I did the same thing on Friday and all was fine until I pulled into my parking spot at home and it went off.
Anyone have any suggestions? I really hope this isn't an issue with the oil pump because I really don't have the money for how much that would probably cost me to get fixed... I have never had any issues with this vehicle since I bought it and its only at 90,400 miles (actual miles).
Old Mar 12, 2014 | 01:25 AM
JoshSlash87's Avatar
JoshSlash87
If it flickers, try shutting the engine off and starting it again. My Parents 04 does that once in a while and I believe it could be a instrument panel issue as shutting it off and restarting the engine seems to cure the oil light.
Old Mar 12, 2014 | 06:44 AM
Corwin613's Avatar
Corwin613
Yeah that works for a while until i drive it again
Tuffy says i need the PCM reflashed while when i took it in to the dealership to get that done they said its the oil pump and charged me 50$ for less than 30 mins of work and for hooking a uncalibrated mechanical gauge to it
