2nd Gen Durango 2004 - 2009
Transmission shift hard going into 3rd gear sometime??
Old Mar 16, 2014 | 04:45 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
My transmission is shifting hard going into 3rd gear sometime it will shift smooth and sometime hard any suggest what may be the problem?
I was thinking taking to the dealership for a transmission service fluid and filter change to see if that help.
2005 Dodge Durango 3.7 119,258 miles .
Another question this model have a kick-down or tv cable where you can adjust you shift point as the preview model? Thank
Old Mar 16, 2014 | 09:13 PM
moe7404's Avatar
moe7404
i am NOT a trans expert. but how a trans releases one gear can effect going in to the next. try and check out the 2 gear band adjustment. i think it can be done on the out side. i have found that if the valve body has been modded the adjustment is not same as stock. on stock set up you might try a little tighter band setting. but ask an expert how far to test out.
Old Mar 16, 2014 | 09:16 PM
1969CoronetR/T
vaffanculo
master tech is the transmission expert on this site.
FF
Old Mar 17, 2014 | 08:39 AM
Harricharan's Avatar
Harricharan
FF
can you tell him to come here or you know where he can be found ? thank
Old Mar 17, 2014 | 08:41 AM
Harricharan
I think when the dealership do a trans service they change the filter and fluid do you know if they adjust the band too ? thank
