2nd Gen Durango 2004 - 2009
front fan/blower not working
Old Oct 6, 2014 | 11:24 PM
ritzy818's Avatar
ritzy818
Default front fan/blower not working
2004 Durango SLT 5.7 - Front blower not working. Replaced resistor (was melted badly). Checked fuses and relay, all checked out good (if I found all of them). But I checked fuses under steering wheel as well as under the hood and they seem to be all working. I have no power to resistor. Also, I have no power to the switch in the dash that controls the front blower speed. There is power to the rear switch to control rear fan setting, and rear heat does work. There is power at the blower motor relay under the hood. But that seems to be where it stops. What am I missing? In-line fuse? Any ideas would be greatly appreciated. Thank you. Please don't post comments to replace resistor. Did that. Blower/Fan is also good as well.
Old Jan 2, 2016 | 07:35 PM
Kadyo300's Avatar
Kadyo300
Default Same problem here
Originally Posted by ritzy818
2004 Durango SLT 5.7 - Front blower not working. Replaced resistor (was melted badly). Same problem hereChecked fuses and relay, all checked out good (if I found all of them). But I checked fuses under steering wheel as well as under the hood and they seem to be all working. I have no power to resistor. Also, I have no power to the switch in the dash that controls the front blower speed. There is power to the rear switch to control rear fan setting, and rear heat does work. There is power at the blower motor relay under the hood. But that seems to be where it stops. What am I missing? In-line fuse? Any ideas would be greatly appreciated. Thank you. Please don't post comments to replace resistor. Did that. Blower/Fan is also good as well.
Let me know if you find out the problem same thing has happened to me
Old Jan 5, 2016 | 08:25 PM
Gildo's Avatar
Gildo
Just this week I replaced the resistor pigtail on my wife's 07' Durango. Sometimes it would only work when wiggling the connector. Looking at the end of the connector the largest wire was burned in the connector. I think this is the one that supplys 12v to the resistor. Probably not the problem you have, but work a shot.
Good luck.
