2nd Gen Durango 2004 - 2009
eps/check engine/anti swerve
Old Nov 5, 2014 | 08:13 PM
amandamay732's Avatar
amandamay732
Default eps/check engine/anti swerve
I have a question, I have a 07 durango. I got gas one day after that it died on me on my way home, started back after a couple tries. Then the next day all these lights came on and it won't start after the lights come on. it'll turn over just not start. It'll start with starter fluid. Could someone help please???
Old Nov 6, 2014 | 08:08 AM
Durango marty's Avatar
Durango marty
ok lets start with a few things was it raining the day this first happened? also what light are coming on?
Old Nov 6, 2014 | 08:12 AM
Durango marty
also you need to pull the codes the way to do this is cycle you key to on,off,on,off,on when i say on i mean do not start it just turn key to on position. if you do this correctly it should show you codes where you odometer is and they will look like (P0856)ect. when they are done the odometer will say done this will help alot in finding out what is going on
