Transmission upgrade for towing
I have an 08, 5.7 hemi durango. (4x4)
I bought a 5000-6000 lb travel trailer.
The trailer is new, and dry. (Water and septic empty).
Towing from Idaho to California, going up hill maxed out at 50 mph.
I can handle going on slow road trip. My concern is that I had to really feather the gas to get to a sweat spot. Too much gas and it felt like tranny was slipping. Engine sounded louder, rpm revved, speed dropped, temp shot up.
I would pull over for 10-15 min. Start again, as long as I kept feathering gas under a certain rpm, I would still loose speed, but temp would not climb as fast. If temp climbed too high, everything started all over again... Loud winding engine, loss of power.
For a bit I was worried I would have to get towed home.
Any suggestions?
New/rebuilt transmission?
Torq converter?
Put in aftermarket beefier tranny?
Or buy bigger truck? Ram 2500?
Any suggestions?
Torq converter?
I'm towing my 5k travel trailer with my 08 aspen with 120000 miles. It does really well. I was concerned with the Hemi's ability, then noticed during a tune up that it appeared that the previous owner did not change the spark plugs on schedule. It was running well, but I switched up to 91 octane and my gas mileage went down... I did the tune up and the difference was very notable. How's the engine temp, I noticed that even when towing in 90 degree temps that it stays in the 210 - 215 degree range. When it gets hotter, it seems to increase the Trans temp (I wish I had a gauge for that) and causes sluggish shifting and dropping into lower gearing. Just a few thoughts.
