2nd Gen Durango 2004 - 2009
4 wheel drive slips going around corners
Old Jan 27, 2017 | 03:09 PM
Pokezy's Avatar
Pokezy
Default 4 wheel drive slips going around corners
I have a 2006 Dodge Dakota SLT. When I put it in 4 wheel lock, the inside wheel will slip going around a turn. Is it truly in 4 wheel lock? It did not do this before.
Old Jan 28, 2017 | 10:50 AM
primem's Avatar
primem
on dry pavement something got to slip as all 4 wheels are turning at different speeds. you should feel a driveline bind up. this is stressful on the tcase and is why the part time 4wd should only be used with loose traction conditions.
has the fluid been changed and was the friction modifier put in?
