2nd Gen Durango 2004 - 2009
Rear A/C expansion valve location???
Old Mar 7, 2017 | 03:29 PM
Carlos Restrepo's Avatar
Carlos Restrepo
Default Rear A/C expansion valve location???
Can anyone tell me where the rear A/C expansion valve is located in a 2006 Dodge Durango Limited 5.7 Hemi. I would really appreciate any help guys!
Old Mar 14, 2017 | 02:27 PM
LONEWOLF2007's Avatar
LONEWOLF2007
Its located in the passenger side of the rear cargo area, behind the small vent. You can see the A/C plumbing under the truck going up in the cargo area, the valve is attached righ up to this lines. Change it is a simple procedure, just need ssome disssasemble of the interior trim panels and 1 allen key.
Just be sure to release/empty the A/C gas before you remove the valve or you'll have a mess. Install the new one, vaacuum the sysstem and recharge the with r-134a gas.
Durango 2nd gen, rear A/C expansion valve.
Old Jul 26, 2023 | 10:00 AM
mjt7277's Avatar
mjt7277
Default 2007 Dodge Durango ac problem
I ahve a 2007 Dodge Durango 5.7 Hemi just had a new compresser put on its stops blowing cold when i stop and there is a hissing from rear of vehicle
