2nd Gen Durango 2004 - 2009
2006 Durango starting issues. Please help
Old May 16, 2017 | 06:34 PM
Freestyle121's Avatar
Freestyle121
Default 2006 Durango starting issues. Please help
I need help if you can. My Durango 4.7 for some reason doesn't start in the morning depending on temperature is my association but learned hot or cold doesn't matter. I turn the key to on the dash lights come on but no crank just a clicking sound. After numerous turns of the key and 2-3 hours later it starts right up with no issues. No CE light sometimes gas cap code comes on and off. Replaced Starter, same issue, replaced ignition switch same issue and took it to the dealer for a diagnostic with no help at all but stating Intemittent operational switch. Recommended changing the lock cylinder. We changed the lock cylinder but kept the same keys and still same issues. The dealer found voltage on wires normal with no shorts. But codes of B212D -stored ignition run only input circuit open. Also code B2101- stored ignition run/start circuit low. Ignition switch and cylinder Plus starter and new battery. But still having this painful issue occasionally at startup after the car sits overnight. Please help.
