2nd Gen Durango 2004 - 2009
07 Dodge Durango SXT Instrument Cluster Bulbs
Old Oct 23, 2017 | 02:07 AM
NoVaStar703!'s Avatar
NoVaStar703!
Default 07 Dodge Durango SXT Instrument Cluster Bulbs
Hey all.
Just wondering if anyone knows the type/size of the OEM light bulbs for the instrument cluster of a 2007 Dodge Durango SXT?
I wish to change the color of the lights from the original green to LED blue. I have changed the color of the AC panel to blue when I installed a new stereo receiver that used blue lighting. The type/size of the replacement LED lights that I used for the AC panel is NEOWEDGE LED T5 from the VLEDS website. I only matched the bulb size with the OEM based on images of the OEM bulbs I found online, matched the base types, and took a flyer on it to a match.
Now, I don't know if the instrument cluster uses the same setup as the AC panel, or uses another set of bulb type/size. There are no images online that shows the back of the instrument cluster for the 07 and no mention anywhere of what bulb type/size the 07 uses for the instrument cluster. I don't want to dismantle the dash before getting the new bulbs.
Can someone help with identifying the instrument cluster bulb type/size for the LED replacement?
Greatly appreciate it.
Old Dec 13, 2017 | 03:03 PM
aido62's Avatar
aido62
Hi NoVaStar,
Did you ever get an answer to this question? I have the same vehicle, and the green backlit cluster is a HUGE distraction driving at night. If I use the dimmer, I can't see the radio or AC panel. I would love to change the color. I've also heard of blacklight LED bulbs that fit, and I wonder if that might solve my problem??
Old Dec 18, 2017 | 11:52 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
PC74 is the cluster bulb. Use that number to search for compatible LEDs
