2nd Gen Durango 2004 - 2009
It's a tricky one....
Old Dec 14, 2017 | 09:27 AM
TheWifesCar's Avatar
TheWifesCar
Angry It's a tricky one....
Hey All,
My wifes 2004 durango won't start....Here's what happened.
The upper radiator hose started leaking pretty bad, it sprayed pretty good in the engine area. I did a flush and replaced the upper hose and everything was fine for about a day or two. She came home, parked in the driveway. We went out about 20 mins later and it wouldn't start. It will crank, but it won't start. I noticed that the oil sensor connection was soaked. I unplugged the battery and cleaned it off and dryed it the best I could, still nothing. It doesn't look like any of the other electrical connections got wet.
Any ideas on what I could be missing? It does give a code of P 0522 which is the oil sensor I think, but I have been told that won't cause the engine not to start. I did have a friend run a scan tool on it and it also said the Auto shutdown was enabled. Is there a way I can reset that or clear it?
Thanks for any help!!!
