2nd Gen Durango 2004 - 2009
Battery drain 05 Limited
Old May 22, 2018 | 04:00 PM
Swexal's Avatar
Swexal
Default Battery drain 05 Limited
Hello. I have a battery drain on my 05 Limited so my battery is dead over the night. I disconected my negative battery cabel and hook up my meter and messured 2,5 amp after 5 min whit all the doors closed (car should be in sleep mode). I started to pull fuses and finaly got to the fuse F15 (15amp) in the interior fusebox and the meter fall to 46mA. I see in the manual that this is the fuse for
Battery Feed Blue Tooth, Compass/Trip Computer (CMTC), Sentry Key Diagnostic. I realy cant find out of this drain, so Im tired of knocking my head to the dash😣
So if any in here have a answear or some how to do i will be greatfull😊
Old May 23, 2018 | 02:37 PM
Swexal's Avatar
Swexal
Default Found the Drain
I did find the reason for the 2,5 amp drain. Is was the overhead console and the trip/compass module. Is the display who have a short, you can see the black field in the display (red circel)
Old May 23, 2018 | 03:02 PM
Nice find.
