2nd Gen Durango 2004 - 2009
a/c clutch repair
Old Jun 6, 2018 | 03:05 PM
hammer16's Avatar
hammer16
Default a/c clutch repair
i have an'08 durango that when the a/c is on it squeals bad i would like to change the clutch and bearing in it and would like any info i can get to help me with this thanks
Old Jun 6, 2018 | 03:54 PM
What kind of info do you need? You will need to get the right clutch repair kit for the compressor you have and then replace it....are you sure it's the clutch and not the belt or pulley?
Old Jun 7, 2018 | 02:53 PM
hammer16's Avatar
hammer16
I have just replaced the alternator and started the Durango and when the a/c is on it screams but when the a/c is off it doesn't make a noise so I am thinking that it's the clutch and bearing. I have never changed this before so I am hoping that I can get any tips I can as far as doing this. I'm not totally ignorant to turning wrenches so just need a little guidance on it
thank you
Old Jun 7, 2018 | 03:40 PM
You tube has lots of informative videos on the process.
