2nd Gen Durango 2004 - 2009
Power Windows problem - module question
Old Sep 17, 2018 | 02:34 PM
2006Durango's Avatar
2006Durango
Default Power Windows problem - module question
I have an 2006 Durango. All power windows switches and the cigar lighter quit working at the same time this morning. I was charging a laptop with the cigar lighter when these quit this morning. So something like a module burnt up I think. I checked the internal fuse block and there's no power coming into F11 (heated mirrors) and F17 the cigar lighter now. But both fuses are good, but no power to these fuse ports though. I checked the power window master switch and it's not that, because there's no power coming into it. I even took the door off and tested at the connection block that plugs into the door column and there's not power coming into that. I'm positive it's not a broken wire. All the fuses under the hood are not blown. So, I need to know what module feed power into the master power window switch?? I think I fried that module for a couple of things to just stop working at the same time instantly and not power coming into the two interior fuses. I read the multi function front control module description and didn't see that it covers power windows, it there another or did I miss it? Any help on where to look?
