2nd Gen Durango 2004 - 2009
ignition switch or cylinder?
Old Jan 26, 2019 | 04:44 PM
crisswilson's Avatar
crisswilson
Default ignition switch or cylinder?
2006 awd with the 4.7 engine. recently when i turn the key to start it the starter sounds like its stuck. if you slightly back the key off and push inwards it will fire. Also with the engine running the key can be removed from the ignition.
Not sure if I just need to replace tumblers in the cylinder or if the switch is going bad.
tia
