2nd Gen Durango 2004 - 2009
04 Durango gives me 2 OBD1 codes .U1411 & U1120 .
Old Jul 22, 2019 | 09:31 PM
William Ulery's Avatar
William Ulery
Default 04 Durango gives me 2 OBD1 codes .U1411 & U1120 .
I am at a lose of finding out what going on .(1) my shifter won't come out of park gear I did use WD-40 on the slider that unlocks the shifter it worked for 2 days then it won't come out again & now I have a ABS light on & a Brake light on in the Dash .
And I have no brake light or running light on the driver's side & a engine light & my speedometer quite working .
I check all fuses & check for continuity on the relays and all were good .
I have no power to the driver's side rear light except turn signals .I checked the brake light switch on the brake pedal it has 12 volts going in & out .I am looking 4 any help thank you .
