2nd Gen Durango 2004 - 2009
@004 Dodge durango 5.7 No brake lights ,Cant get trans out of park gear
Old Sep 2, 2019 | 09:41 PM
BBICLBIC's Avatar
BBICLBIC
Thumbs up @004 Dodge durango 5.7 No brake lights ,Cant get trans out of park gear
well if this happens to your 2004 Dodge durango 5.7 .Gear shift wont come out of park gear ,No brake lights ,ABS ,engine ,Brake light come on in your dash cluster . 1 check your fuses & relays & your Bulbs .If all good check out the interior kick panel Fuse holder & Disconnect your Battery .Unplug all the Big plugs that plug into the that box & pull all fuses & your 3 relays .Look at the male plugs that plug in for mold or corrosion & take the fuse box apart & check your computer board for corrosion ,This what i found today after looking for weeks & replacing parts that did not need to be replaced & cost money . To get the corrosion use 91 % to 100 % rubbing alcohol to clean all of it & use a can of Air to dry it off after about 30 mins .Plug it all back in hook battery back up & it will fix you issue .Thank God ..
