Replaced Alternator. Now ABS, Brake and TPS light's stay on.
I replaced my alternator after it went out and now my dash lights will not go out. The ABS, TPS and brake lights are lit constantly. The check engine light is off though. I have tested every fuse, tested the alternator and battery (battery light is off). I have also tried to reset the PCM/ECM by removing the batter cables...(I can't find the fuse I need to use)
Any ideas on getting these lights off?
