2nd Gen Durango 2004 - 2009
idle engine misses and revs it's self?
Old Jun 25, 2020 | 08:53 PM
p5200's Avatar
p5200
Default idle engine misses and revs it's self?
When in park idling engine has a slight miss and, pushing down the accelerator pedal and holding it down starting at about 2500 rpm holding pedal steady, the engine starts revving it's self while holding gas pedal steady? any help would be greatly appreciated! Took it to mechanic paid $300.00 ran great for one day now it's doing same thing again It's an 07 model with 4.7l engine
Old Jul 29, 2020 | 05:41 AM
kuzmich's Avatar
kuzmich
Most likely the problem is in the cable going from the pedal to the throttle valve, somewhere the cable is jammed and the speed rises
Old Mar 10, 2021 | 07:12 PM
sccschwab@aol.com's Avatar
sccschwab@aol.com
Does the 07 4.7 have a throttle cable?
My 06 5.7 has all electronic throttle with an accelerator pedal sensor, plus a throttle position sensor integrated in the throttle body.
You can try cleaning the throttle body. Search for YouTube videos to see how to do it. If that doesn’t work or you can confirm the integrated TPS has gone bad with a scan tool, then replace the throttle body assembly.
