2nd Gen Durango 2004 - 2009
ABS Error C1060
Old Jul 11, 2020 | 09:15 PM
MacSavers's Avatar
MacSavers
Default ABS Error C1060
I keep getting this error: C1010 - Left Front Outlet Valve Control Circuit Low
I'm not sure if I should replace the ABS sensor on the driver front wheel or if the problem is something else. I've checked everywhere I can find on the internet and I've had no luck whatsoever.
Anyone here got a clue?
Old Mar 15, 2021 | 10:33 PM
Dallin Drescher's Avatar
Dallin Drescher
did you ever figure this out? Having the same thing on mine.
Old Mar 16, 2021 | 03:45 AM
MacSavers's Avatar
MacSavers
Yes. I replaced the ABS Pump. That fixed it.
Old Mar 16, 2021 | 12:42 PM
Dallin Drescher
Thank you, that's super helpful. Did you do it yourself? Just wondering if there's a special procedure for bleeding it.
Old Mar 16, 2021 | 01:45 PM
MacSavers's Avatar
MacSavers
No bleeding was necessary. You have to disconnect the battery and access it from the driver's side wheel well, but it was not difficult.
