2nd Gen Durango 2004 - 2009
04 Durango passenger side water leak
Old Apr 1, 2021 | 02:17 PM
04durangohemi's Avatar
04durangohemi
Exclamation 04 Durango passenger side water leak
Water without the smell of coolant and it’s not the ac drain. My evaporator is shot so ac doesn’t work. After heavy rain the passenger side is soaking wet. I’ve already replaced the windshield with no effect to the leak. I saw a video about a ram that had the windshield support block was leaking but I wasn’t sure if that could be it for the Durango as well. Please help
Old Jun 20, 2021 | 05:13 PM
DanDurangoMan's Avatar
DanDurangoMan
It could be the cowl seals or the main hood seal from the hood to the engine. There's a Youtube on top 5 2nd generation problems Durango.
Old Jun 20, 2021 | 05:20 PM
04durangohemi
Default Problem solved
it was the windshield support block, it hasn’t leaked since it was resealed. It was leaking into the air intake for the heater and A/C under the cowl.
Old Aug 7, 2021 | 10:54 AM
waynetab's Avatar
waynetab
Had same problem here and found the sunroof drain hole on passenger side was blocked.
long piece of wire unblocked it and all well
