2nd Gen Durango 2004 - 2009
Losing oil
Old May 23, 2022 | 06:08 PM
Matts824's Avatar
Matts824
Default Losing oil
So my 08 Durango is losing oil and I can't find out where. It's going. Any ideas as to where it could be going?
Old May 23, 2022 | 09:07 PM
Calamity Coyote's Avatar
Calamity Coyote
If you are not seeing any leaks underneath (puddles on the ground), you are probably burning it out the exhaust. Could be due to stuck rings. I was having this issue with my 08 Aspen when I got it. Would burn through a quart of Amsoil every 600-800 miles. Dealer tried to tell me this was normal. None of my other vehicles would loose oil at this rate and I drive them all hard. My 95' Ranger had over 330k miles on original motor and trans and never burned at this rate.
I switched to Castrol High Mileage oil with a bottle of STP treatment in the blue bottle and now get 1300-1500 before having to add any. Also be sure to use the recommended 5w-20 weight. Any thicker will cause issues with the MDS and any thinner will seep past rings and burn.
Old May 23, 2022 | 09:13 PM
Matts824's Avatar
Matts824
Ok awesome! I mean when I got it, it had 25 miles on it. Its been a great vehicle. Just trying keep it maintained
