2nd Gen Durango 2004 - 2009
XM Radio Built in of FM modulated?
Old May 8, 2006 | 09:40 PM
fsh2xs's Avatar
fsh2xs
Default XM Radio Built in of FM modulated?
Has anyone installed an XM receiver that wires directly between the existing Durango antenna and the socket on the back of the radio? Or am I stuck with a setup that uses an external "fob" that transmits into the car's fm radio?
I had this "hard wired" setup built into my Ford Explorer and there was an adapter avilable for Ford to change the "gender" of the antenna wiring so the XM connectors would mate with the car's antenna and radio plugs.
If you've done this install, where did you tap into the 12 volt power for the XM module?
Thanks.
